Is it possible to teach a Pronto a command with the learn function but then control the equipment sitting in another room with RF?
Thx. mjn I was thinking about the 980 with an RF extender. I just am not clear if a Pronto can 'convert' a learned signal to RF. Reading your answer this should not be a problem. Right?
jaguar, Pronto learns IR (or selected from IR database in Pronto Edit) Pronto converts IR to RF, sends out RF to RF Extender, RF Extender converts RF to IR IR Controls components - either using the RF Extender Flood emitter or individual remote emitters which stick on each piece of equipment (over their IR sensors) So in answer to your question - Yes. Chris.
Guys, can the Pronto also control some devices by RF (e.g. DVD player in cupboard) whilst still using IR for others (e.g. TV in direct line of sight) ?
Yes it can, You just set how you want the signal sent out -IR or RF for each individual device in Pronto Edit. Chris.
