Pronto help!!!!!!
Discussion in 'Home Cinema Control & Remote Controls' started by blakeyboy, Aug 5, 2002.
  1. blakeyboy
    blakeyboy
    Feb 27, 2002
    1,137
    38
    worthing
    +14
    I have just purchased a Pronto RU890. Can anyone help with downloading so I can personalise my remote. Tried the Phillips Pronto site but cannot for the life of me fathom it out. Is this the best site or does anyone know of an easier site. I am not very computer minded and only know the basics.
    Cheers.
    Please help!!!!!!!
  2. Guest
    You have been to Remote Central, haven't you ? Tell me you have...
    Welcome to the learning curve. Me and Mr. Pronto's software have a love-hate thing going on.
    Mike.
  3. blakeyboy
    blakeyboy
    Feb 27, 2002
    1,137
    38
    worthing
    +14
    Mike
    Yes i have been to Remote Central, but I still cannot download, starting to get really P... OFF.
  4. kezza
    kezza
    Jun 30, 2002
    122
    Swindon
    +4
    What is it you are trying to download?
    Regards
  5. blakeyboy
    blakeyboy
    Feb 27, 2002
    1,137
    38
    worthing
    +14
    To be honest I am not really sure. I want to be able to download for the following remotes - CD, AMP, TV, VIDEO, DVD, SKY, TUNER and I understand you can get logos as well. Can you help me with what I am supposed to be downloading and should it be onto the CD that came with the Remote?
    Told you I haven't got a clue!!!!!
    Cheers mate for your help
  6. kezza
    kezza
    Jun 30, 2002
    122
    Swindon
    +4
    Building Pronto configs is a lot of work but to get started you need to download Pronto Edit 4. You can download this from the official Pronto website.
    Once you have downloaded this you can download other peoples ccf's from Remote Central and play around with them until you are happy with the result.
    But if you haven't already get Pronto Edit download it and play around with that to start with then take it from there.
    Regards
  7. blakeyboy
    blakeyboy
    Feb 27, 2002
    1,137
    38
    worthing
    +14
    Cheers Kezza I will have another go at it tomorrow hopefully with more joy.
  8. Phil.LFC
    Phil.LFC
    Mar 31, 2002
    730
    Staffordshire
    +57
    I'm having the same problems as Blakeyboy. I'm not too good with computers either. I have a CD that came with the Pronto. It has a file on it called "ProntoAnne.CCF". When I try to open this using Windows ME it asks what I want to open it with. Well I'm buggered if I know:confused:
    Would it make any difference if I downloaded Pronto Edit from the web?
    Apologies for probably sounding a bit thick, but we're not all a dab hand with these PC's. :eek:
    Perhaps I'd better not delve into Pronto Edit at all as I've read that it can be a bit difficult/time consuming!
    :confused: :confused: :confused:
  9. LeighM
    LeighM
    You need to get pronto edit to get the best out of you Pronto, altough it can be really annoying to use, if your happy just to use a ccf file someone else created for you then it's pretty straightfoward. Just connect your pronto using the cable provided to your computer, open pronto edit open the ccf file and then select download (or transfer or some other command that sounds like that) and bobs your uncle.
  10. blakeyboy
    blakeyboy
    Feb 27, 2002
    1,137
    38
    worthing
    +14
    Glad to see i'm not the only one who can't do it Phil.
