pronto help needed please
Discussion in 'Home Cinema Control & Remote Controls' started by mambojambo, Dec 28, 2004.
  1. mambojambo
    mambojambo
    Dec 23, 2004
    142
    +3
    i just got a pronto RU930 and im having a little trouble setting up
    i`m trying to add items to a button ie when i press dvd on main menu i want to link to dvd power button, amp power button select dvd imput button on amp and jump to dvd menu
    all is well after i enter the commands on the neoedit software but after i save the configuration all the commands have gone from the command list :confused:
  2. Markie Boy
    Markie Boy
    Dec 13, 2002
    1,260
    63
    Perth, Western Australia (Originally Ireland)
    +226
    Make sure you hit the "OK" button in the software while adding the commands - I sometimes make the mistake of hitting the EXIT key in top right corner of screen, which cancels anything you may have entered.
