Pronto Edit. How can you move a group of buttons ?
Discussion in 'Home Cinema Control & Remote Controls' started by dUnKle, Mar 24, 2002.
  1. dUnKle
    dUnKle
    Jan 1, 2001
    15,689
    +2,586
    Just a quick question, how do you move an entire group of buttons easily ?
    For instance when you want to move a group of buttons which make the controls for your DVD player is it possible to group them all together and save having to mess about with each one individually ?
  2. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    Sorry, there ain't no quick way. Unless you copy the whole panel over and remove the bits you don't want.
  3. Paden
    Paden
    Jul 27, 2000
    577
    +23
    Hello there
    I think if the buttons are on a frame then you can select the whole bunch or individually.
    If you look at Daniel Tonks' (Remote Central) transport keys, you can right click on one of the individual buttons & then select "parent" & the whole lot are selected & can be moved as one.
    Cheers, Paul
  4. mjn
    mjn
    May 24, 2001
    23,246
    Herts, England
    +11,498
    if you group the buttons together, like a transport set or numeric keypad, you can cut/paste them.
