Pronto Edit and Color Bmps
Discussion in 'Home Cinema Control & Remote Controls' started by vicbarry, Jul 8, 2004.
  1. vicbarry
    vicbarry
    Oct 13, 2003
    457
    Cork
    +7
    Just started using Pronto Edit and I can get a grey scale BMP into it no problem...How in gods name do I go about importing a Color BMP into it..
    Im using PS 7 and am just about stumped...
  2. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    Can't say I've had any problems other than the fact that you can't have more than 256 colours on a bitmap. I havent used it for a while but, when you go in, I think you can select the type of Pronto you have - you haven't selected a B/W pronto by any chance?
    HTH
    John
  3. SimonO
    SimonO
    Nov 4, 2002
    3,293
    71
    Hertfordshire
    +64
    Which version of ProntEdit are you using and on which remote..?
  4. Jules
    Jules
    Oct 11, 2000
    5,584
    134
    +1,044
    As John says, just make sure you save your images as 256 colour bitmaps and it'll work.
    You'll need to be working on the Pronto's colour palette though, otherwise you'll find your works of art don't look quite the same on the remote.
    There's a great tutorial over at remotecentral.com
    It tells you how to start working with the Pronto's colour palette, and how to make your images look more professional.
  5. vicbarry
    vicbarry
    Oct 13, 2003
    457
    Cork
    +7
    Thanks for the replies, im using Pronto Edit 4
    Selectin US Color. The other thing is i cant seem to save a color BMP in Photoshop 7, cant seem to find the option...
  6. vicbarry
    vicbarry
    Oct 13, 2003
    457
    Cork
    +7
    Ok Got it. Thanks for the replies again. Wasnt using indexed color in PS
