Pronto Docking Station
Discussion in 'Home Cinema Control & Remote Controls' started by mjn, Dec 24, 2001.
  1. mjn
    mjn
    May 24, 2001
    22,422
    Herts, England
    +10,455
    Help.....my pronto docking station, will only charge my battery to 75%!!
    It's the 2 mb of the remote.
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,906
    You seem to be lucky as most will only show 50% (like mine). I think that it is a bug in the software.
    It doesn't seem to affect it's useability though.
  3. mjn
    mjn
    May 24, 2001
    22,422
    Herts, England
    +10,455
    true, it seems to last ok. I upgraded the firmware to the lastest on the site, but made no difference.
  4. Arthur.S
    Arthur.S
    It's a well known bug in the Pronto. Gawd knows why they haven't fixed it after all this time:confused: I've found that after recharging, if you remove the battery, then replace it When the Pronto re-boots, the charger shows as full. Keeps me happy anyway! ;)
