Pronto + coke = awww crap...
Discussion in 'Home Cinema Control & Remote Controls' started by Luc, Apr 6, 2002.
  1. Luc
    Luc
    Aug 7, 2000
    420
    Just spilt coke on my Pronto, not a lot, but over the screen and it turned itself off, anyone else done this and survived? I dropped my phone into a glass of Lilt before and it worked after it had dried out, so i'm not overly worried, but can anyone tell me if Prontos are as robust?
  2. Taz
    Taz
    OOOOPS!:blush:
    Sounds like you and soft drinks dont get on to well eh?
    The problem with Coke is that at this very moment its eating the internals of your Pronto! as its so acidic.. we all know what it does to dirty pennys etc.
    If it were me i'd be trying to dry it as fast as I could.
    Taz.:cool:
  3. Luc
    Luc
    Aug 7, 2000
    420
    Works now, took the batteries out, left it for 10 minutes, and when i put them back in it ummed and urred for a bit then turned itself back on. Disco.
    [As a side note, this is now the official High Wycombe thread. Long live Eden. ;) ]
  4. General Skanky
    General Skanky
    Jul 28, 2000
    4,251
    71
    Colchester
    +44
    For future ref.:).
    If you had another emergency like that and it was last ditch, it is really simple to take apart a remote. Unscrew, pull apart and wipe it out. If you need to clean it, a pure spirit solution, vodka for example would make a good cleaning agent on a lint free cloth. It really is straight forward for 'most' remotes. Just be brave, especially if you think there is nothing to lose.
  5. Taz
    Taz
    Sooo... if all else fails at least you have a mixed vodka and Coke!
    :D :D :D
    Taz.:cool:
  6. General Skanky
    General Skanky
    Jul 28, 2000
    4,251
    71
    Colchester
    +44
    :D
    It's like my cold remedy.
    Warm milk, some sugar and dark rum. If you don't like it at least you'll feel better.:)
  7. Luc
    Luc
    Aug 7, 2000
    420
    I would have done, but the Pronto's got these really annoying star-shaped screws; i've got the right shaped bit, but it's too big to fit in the holes where the screws are.
  8. General Skanky
    General Skanky
    Jul 28, 2000
    4,251
    71
    Colchester
    +44
    Aaaaaaah. I know the type. They are the sort of ones you think you'll never need then one day...........
    Thank God I now own just about every type of screw head in every size known to man in my DIY set up.
  9. Couch Potato
    Couch Potato
    They're Torx screws, the 'drivers are available just about anywhere, I think the Pronto needs either a Torx 8 or 10.
    Steve
  10. Couch Potato
    Couch Potato
    Ah Cold remedies, I prefer Port & Brandy!! Doesn't shift the cold but after a couple you dont care:D
    Steve
