pronto ccf corupted
Discussion in 'Home Cinema Control & Remote Controls' started by patmyhead, Jan 2, 2003.
  1. patmyhead
    patmyhead
    Feb 11, 2002
    588
    I o M
    HI
    what causes the 940 when on down load to display error saveing rc configuration file to large to fit in unknown rc
    the files work ok on the emulator & all worked well yesterday
    did searches & found out it might be pronto edit but as i only downloaded it a couple of days ago i would have thought that any bugs would be sorted out by now
    any ideas M8s
    P@
  2. dnrc
    dnrc
    Dec 23, 2002
    300
    16
    Near Norwich
    i seem to remember this being caused if you choose the wrong pronto version when starting the program.
    i may be wrong however, check out www.remotecentral.com - someone there will know
  3. patmyhead
    patmyhead
    Feb 11, 2002
    588
    I o M
    I dont think this is the case as the day before i loaded 3 ccf's from dirrerent people ok it was only when i tried new files that problems started
    I can load pronto edit from the rc alter it & send it back to the pronto fine
    thanks for help
    P@
