Pronto broken?
blakeyboy
Hi I have a Pronto 890 and love it. I have had it for 2 years now. But now I have a problem, the screen get's distorted with lines going down it. Which makes it hard to read. Is it time to get a new one now or is there some thing I can do to mend it. I don't think I can manage with out one now.
John
I have a similar problem with mine , as a result of a 6 year old , beaker of juice , nest of tables , the wall and a roly poly :mad: to say I was a bit upset is the understatement of the decade (so far).
I think it is possible to swap the display out for a new one , however all the info i can find about it on Remote Central is atleast 2 years out of date .And if I'm honest , probably beyond my capabilities anyway
good luck
John
Hallsy
Mine had very faint dark lines down it, probably about 3 or 4 about 1cm thick. They go away when you turn contast right up but then you loose shading. But when shading is about right you can see that there are some bits slightly darker than others down these lines.
Is this normal for a Pronto 890/940?
blakeyboy
That is like mine but it does go away some times but then comes back. There must be some thing we can do :lease:
John
if it goes away , and come back .That sounds more like a loose connection than anything else . It does not sound normal to me . I never had any lines on my display (other than ones I put there :smashin: )
Its actually very easy to dismantle a pronto , and not beyond my capabilities as I mistakenly stated earlier :cool: Have a look here Very good instructions fory taking it apart .
I'm just weighing up the possibility of getting the new screen from EarthLCD .The site says its not compatible, even tho there are threads on remote central that say the screen will work with a little bit of fettling to the plastic frame :confused: .
$40 for the screen , about the same again for shipping, and the possibility of HMC&E wanting to charge duty on top . To be honest I am considering getting a Harmony of one description or another .
In saying that , My SKY+ remote does the basic funtions for me , so might not even bother with a new remote
Good luck
John
