pronto box
Discussion in 'Home Cinema Control & Remote Controls' started by Craig C, Dec 17, 2000.
  1. Craig C
    Craig C
    Does anyone know the dimentions of the box that the pronto comes in. I have been hinting for ages and the wrapped box under the tree looks about right. Did the wife get the hints?
  2. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    If I remember right its about the same size as a software package maybe a bit bigger. At least the Marantz version is. say 30cm x 120 x 50. Of course if its set in learning mode you could try pointing a remote at the box and listening for the beep. I bet you actually try that. Best of Luck and Merry Christmas anyway
  3. ptmbradley
    ptmbradley
    Aug 15, 2000
    253
    Body in Wolves, heart in Cardiff!
  4. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    But Christmass is all about miracles.
