Pronto advice please!
Discussion in 'Home Cinema Control & Remote Controls' started by mxs, Jan 7, 2004.
  1. mxs
    mxs
    Nov 28, 2003
    236
    Lowestoft
    +9
    Can the 'home' page text in the bordered area's be changed without having to plug the unit into my computer ??
    Any advice greatly appreiciated! :confused:
  2. jsmurray
    jsmurray
    If you mean the the Pronto 890/940's two bottom hard buttons that have labels in the border area, then the anser is yes.
    Just select LABEL from the Mode Menu and hit the button to want to re-label. This is the same procedure for changing any soft buttons too.
    HTH
  3. mxs
    mxs
    Nov 28, 2003
    236
    Lowestoft
    +9
    Just to simplfy my question, I have reverted to the original settings on the Pronto i.e. DVD , TV, CD, etc.... which show on the home page when selected - can the text there be changed?
    I have tried selecting label from the mode menu, and it will not allow me to change the factory settings??
    Very confused at the moment :confused: :confused:
  4. mxs
    mxs
    Nov 28, 2003
    236
    Lowestoft
    +9
    Someone out there must be able to help me with this please!:(
  5. jsmurray
    jsmurray
    I working in Liverpool this week, but will be home on Sunday. I'll reset mine to factory defaults and see for myself.
    If I can help, I will mate. Hang on in there;)
  6. mxs
    mxs
    Nov 28, 2003
    236
    Lowestoft
    +9
    Thanks js, but I have found out how to do it.
    Thanks for your reply.
  7. jsmurray
    jsmurray
    No problem mate. Glad you got it sorted.
