Pronto 950 help please
Discussion in 'Home Cinema Control & Remote Controls' started by Avi, Sep 6, 2005.
  1. Avi
    Avi
    Dec 30, 2004
    13,963
    +2,063
    Hi all
    I've been provided with some IR codes by a manufacturer to access functions that are not provided by their standard remote. The Format is;
    Device Code: 132.138 Function: 50
    0000 006D 0000 0032 007A 003D 000F 000F 000F 000F 000F 002E 000F 000F 000F 002E 000F 000F 000F 000F 000F 000F 000F 002E 000F 002E 000F 000F 000F 000F 000F 000F 000F 002E 000F 002E 000F 000F 000F 000F 000F 000F 000F 000F 000F 000F 000F 000F 000F 000F 000F 000F 000F 000F 000F 000F 000F 000F 000F 002E 000F 000F 000F 000F 000F 000F 000F 000F 000F 002E 000F 000F 000F 002E 000F 000F 000F 002E 000F 000F 000F 000F 000F 000F 000F 002E 000F 000F 000F 002E 000F 000F 000F 000F 000F 002E 000F 002E 000F 000F 000F 000F 000F 0689
    How do I programme the Pronto with this code ??? Help please
  2. msg
    msg
    May 20, 2005
    458
    Darlington
    +10
    Have a browse around the Pronto section on RemoteCentral
    http://www.remotecentral.com/files/index.html
    You should find instructions there for how to copy hex codes via a PC to your remote.
    In fact I've found and copied the instructions - see below....
    How do I use these codes in ProntoEdit?
    All codes found in the "Individual IR Codes" section of this site are presented in ProntoEdit's internal hex format. In order to use them with your Pronto remote control please follow these steps:
    1. In the ProntoEdit or RC5000 Setup software package, double-click on the button you'd like to use the code with. You must already have an IR listing in the action window in order to paste the new hex code into, however if you do not the easiest way to create one is to click on RC5/6 ("Set IR" then "Advanced" in ProntoEdit v2.0, RAVedit or RC5000 Setup v2.3) and choose the default listing (0 0). In ProntoEdit v2.0 or RAVedit you can also add a new database code entry (just press "Set IR" then "OK").
    2. Next, double click on the entry (shown as "[C] RC5 0 0" if you added an RC5/6 code, "[C] Learned" if you are replacing an existing code, [C] Yamaha 00 00 if you added a Yamaha code, or "[C] UDB" if you used the database). In ProntoEdit v1.05 or lower and all RC5000 Setup versions, this will open a new window with the hex code displayed for that function, already highlighted for easy replacement. If you are using ProntoEdit v2.0 or RAVedit you must click on "View IR" and manually highlight the hex code to replace.
    3. Return to your web browser and select the code you'd like to use by clicking and dragging the mouse cursor over it. Copy it to the clipboard using the CTRL-C keyboard shortcut.
    4. Next, switch back to ProntoEdit and paste the code into the opened window using CTRL-V. If you cannot paste the code in ProntoEdit v2.0, click here. If you're using ProntoEdit v1.05 or RC5000 Setup v2.2 (or older), you can rename the code's internal listing by clicking on the text at the bottom left, otherwise press OK to return to the button's property screen. That's it!
    PS Don't copy "Device Code: 132.138 Function: 50" as this is not part of the hex code
    Dave
  3. JurgenNL
    JurgenNL
    Jun 12, 2002
    282
    +20
    dazzerxxx,
    And probably you could tell us then how it works. ;)
    Jürgen
