Pronto 950 and X-10
Discussion in 'Home Cinema Control & Remote Controls' started by milanlad, Jan 29, 2004.
  1. milanlad
    milanlad
    Sep 10, 2002
    359
    West Yorkshire, UK
    I'm trying to figure out what I need to do to set-up functions on my Pronto to send out Infra-Red X-10 signals? I have an IR-to-X10 converter.
    Will the Pronto 950 send out both IR X-10 and RF X-10 signals?
    Thanks in advance
  2. RichardJ
    RichardJ
    Jan 27, 2003
    Shropshire
    +6
    If its a UK version then the 950 will work on IR and the X10 RF frequencies
  3. richkeys
    richkeys
    Jan 16, 2003
    19
    London UK
    goto www.remotecental.com for infrared X-10 codes for your pronto.
    see http://www.letsautomate.com/10162.cfm? for a infra-red to X-10 converter.
    I have this set up it works perfectly.
    If you want my Pronot CCF follow the link to my home cinema site at teh foot of my reply.
    Regards,
    Richkeys.
  4. milanlad
    milanlad
    Sep 10, 2002
    359
    West Yorkshire, UK
    I had a look at remontecentral but could not find the infrared X10 codes for the Pronto 950?
    Please could soemone point me in the right direction.
    Also, can I just check something - does the RU950 Pronto send X10 signals in both IR and RF format?
  5. richkeys
    richkeys
    Jan 16, 2003
    19
    London UK
