Pronto 940 USB Serial Converter!!!
Discussion in 'Home Cinema Control & Remote Controls' started by MarkR, Nov 26, 2003.
  1. MarkR
    MarkR
    May 3, 2003
    1,900
    Somewhere in Kent
    +344
    Dont know if any Pronto owners are interested but just in case....
    After buying a new laptop I discovered that it did not have serial port, which of course makes your Pronto redundant in respects to uploading and downloading CCFs. A while ago I seeked advice to whether a USB serial converter would work, some people said yes and some said no. So for reference it does work to my huge relief.:)
  2. Zapp.Brannigan
    Zapp.Brannigan
    Jul 14, 2003
    169
    Manston, Ramsgate
    +3
    COOL!:D :D
  3. Boink!
    Boink!
    Oct 5, 2002
    599
    +35
    How much are these converter connectors and where can you get them from?
  4. MarkR
    MarkR
    May 3, 2003
    1,900
    Somewhere in Kent
    +344
    Hi Boink, I bought the converter from Ebuyer, think it was around the £12 mark.:)
  5. Dan666
    Dan666
    Jul 4, 2002
    144
  6. MarkR
    MarkR
    May 3, 2003
    1,900
    Somewhere in Kent
    +344
    That looks identical to the one I have. I take it you are in a similar situation??
  7. Dan666
    Dan666
    Jul 4, 2002
    144
    Sort of - I use my PC to configure the Pronto. The box sits under the desk so the serial ports are a bit awkward to get to.
    There are USB ports on the front of the case so I'd like to utilise one of these instead.
