Pronto 940 repairs
Discussion in 'Home Cinema Control & Remote Controls' started by mseabroo, Dec 21, 2004.
  1. mseabroo
    mseabroo
    Aug 28, 2001
    376
    28
    Sussex
    +41
    Anybody have experience or contact details of companies that can provide a repair service for the pronto 940 ?
    Is is even likely to be economical to repair ?
    Mine has developed a habit of sending random codes and jumping about between menu's. I suspect it may be a fault with the touch screen as one of the little darlings has put a bit of a dink in it. So think there may be a permanent "touch" thing going on.
    Any references, experiences etc gratefully received.
