Pronto 940 or Dell Axim 300mhz
Discussion in 'Home Cinema Control & Remote Controls' started by Rickyj @ Kalibrate, May 6, 2003.
  1. Rickyj @ Kalibrate
    Rickyj @ Kalibrate
    Well-known Member AVForums Sponsor
    Jan 29, 2003
    5,849
    Surrey
    +1,846
    I was all set to go and buy a Pronto 940, with docking station, that i can pick up for about £175, but have since found out about the Dell pda for £200 (300mhz version). Can anybody tell me whether the 300mhz pda is suitable, or would it need to be the 400mhz version for better control of my home cinema system.
    Any views on the above remote/pda would be greatly received.
    I understand that an ir extender would be needed, and remote software for the pda, but the pictures look so much better.
    Thanks in advance
    Ricky
  2. purple52
    purple52
    Jan 10, 2002
    41
    11
    London
    The 300Mhz Axim doesn't include a docking cradle, which costs around £30 extra. Other than that, I can't see why the 400MHz would offer much advantage if you're only going to use it as a remote.
    Having said that, I don't actually own one...
    David
  3. nathsea
    nathsea
    Apr 26, 2003
    920
    +24
    Hi all
    I`ve been thinking about this new pda from dell also, does anybody know if it is proper touchscreen ie i can push it with my finger and it will launch the command or do I have to use one of those stylus type things. Sorry for the posibly stupid question!!
    Nathan
  4. Loada
    Loada
    Mar 4, 2003
    592
    Guisborough, North Yorkshire
    +51
    Most PDAs can be operated with a finger (nail) but I've always found them to not be as touch-sensitive as the Prontos.
  5. dts_boy
    dts_boy
    Nov 26, 2001
    2,615
    Manchester suburbs...
    +178
    i got a theater master mx 700 with my new processor and was using a rc5200 before that. the marantz has been gathering dust ever since...the theatre master is much better in my opinion - i like buttons better that touchscreens. it worth checking out as the ir range on pdas aren't great, you'll have to get an ir extender as well
  6. paulryan
    paulryan
    Sep 2, 2002
    47
    Kent
