Prologic IIX, Neo6, Neural THX which one for 5.1 setup?
Discussion in 'AV Receivers & Amplifiers' started by Freefall123, Feb 10, 2009.
  1. Freefall123
    Freefall123
    Dec 26, 2008
    33
    I have a Sony DA2400ES and 5.1 speakers. In the the amp configuration for Enhanced Surround mode I can choose between Prologic IIX, Neo6, Neural THX which should I choose and whats the difference?
    Freefall
  2. Mark.Yudkin
    Mark.Yudkin
    Sep 19, 2007
    10,045
    Zurich, CH
    +1,542
    You should choose none as you have a 5.1 speaker setup. The Enhanced Surround modes are for 7.1 (or 6.1) setups.
  3. Freefall123
    Freefall123
    Dec 26, 2008
    33
    You would think the option would be greyed out then -as it knows I have a 5.1 setup.
  4. IAN P
    IAN P
    Dec 11, 2002
    8,285
    +1,042
    Have a listen.On my set up Neo 6 sounds better than others.
    Yours could be entirely different.
    You can add these effects to stereo sources as well such as Sky,works quite well too.
  5. Mark.Yudkin
    Mark.Yudkin
    Sep 19, 2007
    10,045
    Zurich, CH
    +1,542
    Misleading user interface design never ceases to amaze me either, so I've stopped thinking such things.
  6. qfk123
    qfk123
    Mar 11, 2002
    1,075
    +93
    If your Talking about AFD Esurround option then it is a method of extracting multichannel sound from only a 2 channel stereo source.
    Mine is set on AFD Esurround ( prologic 2 ) That way i get all the full dolby 5.1 sound , HD formats on sky HD and ps3 but programs like eastenders and non multichannel programs (blue light is off) Get abit of rear surround action.
    Leave it on E-Surround ( prologic )
  7. Freefall123
    Freefall123
    Dec 26, 2008
    33
    Thanks, I'll do that. Thanks to all for your replies.
