projectors
Discussion in 'Projectors, Screens & Video Processors' started by antonOO2, Apr 12, 2003.
  1. antonOO2
    antonOO2
    will i be able to get a second hand projector that will do a fairly gud job on a hokme cinema system ,my first for about 300 pounds
    Any recomendations?
    thanks anton
  2. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,153
    UK.
    +2,671
    At that price, unlikely, but double it, and you may find something.
    CRTs are big, but if you look on the classifieds, there was one going for £500.
    Gary.
  3. antonOO2
    antonOO2
    i have been lookin on ebay ,the uk one .i dnt know what to look for though ,as i dnt know anything about them .any advice
  4. nathan_silly
    nathan_silly
    My mate bought a Electrohome 4100 CRT Projector for £600.
    No CRT burn, and pretty good picture.
    CRT- big things with Red, Green, Blue guns & lenses. Heavy, but better picture than LCD - IMO. Tricky to setup- converging/focus of each lens. CRT guns are expensive to replace. Good black detail.
    LCD- small, with a LCD matrix & bulb. Light. Easy to setup. Single lens. Expensive bulb - £200+ , LCD matrix pixel death, and noisy & heat due to the bulb. Poor black level (dark grey, not black)
  5. antonOO2
    antonOO2
    any info on the below item :
    Zenith PRO861X CRT
    cheers
    its a crt screen just wonderd wht it was like as i can get one fairly cheap
