Projectors & Macrovision
Discussion in 'Projectors, Screens & Video Processors' started by Mike Dando, May 22, 2002.
  1. Mike Dando
    Mike Dando
    Does a DVD players Macrovision have to be disabled in order to drive a projector?
  2. Panicsony
    Panicsony
    Should not be a problem. A projector is just like a TV with a different light source.
  3. Guest
    Panicsony is a great name! Wish I had thought of it...
    I have used several Sharp projectors in the past that have been effected by Macrovision (ie constantly fading/brightening), but this was 3 to 4 years ago. The Infocus, Davis and Sony units that I have used over the last couple of years where ok though.
    So I guess that if you going to get a new unit you should be OK, but a secondhand or older model may be effected!
