Projector
Discussion in 'Projectors, Screens & Video Processors' started by R0B, Sep 6, 2012.
  1. R0B
    R0B
    Aug 30, 2012
    Hey guys basically i have £1500 to spend on a projector anyone got any suggestions ill be be playing ps3 and watching dvds on it if thats any help. Thanks!
  2. Tight Git
    Tight Git
    Mar 3, 2004
    6,331
    +597
    This section is for projector screens... :)
  3. Lee
    Lee
    Mar 2, 2006
    5,846
    +2,696
    so I'll move it to the projectors forum :)
  4. R0B
    R0B
    Aug 30, 2012
    My apologies sorry!
  5. toddy28
    toddy28
    Aug 20, 2007
    3,634
    +685
    Welcome to the forums rob
    Now about your question ;)
    Room size ?
    Room light control ?
    Budget for screen ?
    What av gear do you already have ?
    In general you need to add more to your question its like me asking you what car to get !!
    2 seater 5 seater 7 seater , petrol , electric , red , blue , black , green
    As you can see the list is endless the more info you give the more help you will get ;)
  6. R0B
    R0B
    Aug 30, 2012
    Wow didnt know there was that much to it! I dont know room dimensions yet as havent moved in and not been able to get measurements as its a new build ill try get them as soon as possible.
  7. toddy28
    toddy28
    Aug 20, 2007
    3,634
    +685
    There's a lot to it , :)
    As they all have different throws ( the size of the image from different distances )
    And there are different types the main 2 being dlp
    And LCD
    Also you will need a sound system as most don't have speakers and the ones that do are poor quality
    Best thing for you is to go to an av shop and have a look and talk through projector options with a dealer , you might find a large 60 " tv might be a better options , a lot of my mates wanted a projector but most ended up with a large tv because of the wife and the expense of the sound system , mounts and screen even when I said I would set the whole thing up for them
