Can someone give me a 101 on projectors, as I know absolutely nothing about them?
1. whats the difference between lcd, dlp and crt?, what are the pros and cons of each?
2. What are some of the recommended projectors out there and how much do they cost?
3. Can I put a projector on the floor or ceiling (which both would create an angle in relation to the wall) and how far must it be away from the wall(I dont know what you call the thing that the image is projected on)?
4. Are there any cons on projectors... fan noise, convergence problems, short life span, focus?
5. Do they have all the connects that I need, rf(for tv), components(that take progressive), SDI, scart ??
6. Do they have inbuilt scalers/deinterlacers or is an outboard one best?
7. What signals can they take, SDI, pal/ntsc progressive, HD?
8. What resolutions do they project?
9. How do I go about watching tv.. do I use the crappy vcr tuner(that doesn´t have teletext)?
10. Something about ratios(which I hardly understand).. 4:3, letterboxed, anamorphic?
11. Am I forgetting anything?
