Projector stand (moveable)
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by WoodyAllen, May 15, 2004.
  1. WoodyAllen
    WoodyAllen
    Jan 19, 2004
    91
    Northern Ireland
    +4
    Seeking an aesthetically pleasing stand for my ae500pj; not a fixed installation so will be moved around the room frequently. Something in a light wood / glass finish would be nice but not looking to spend a pile of money. Any ideas?
    :hiya:
  2. bobbypunk
    bobbypunk
    http://www.standsunique.com/ click on designer furniture and storage solutions.
    have a look half way down, wouldn't be cheap but castors are also an option so exactly what you're looking for!!
  3. WoodyAllen
    WoodyAllen
    Jan 19, 2004
    91
    Northern Ireland
    +4
    Cheers mate: stylish kit for sure...with prices to match unfortunately!! It might have to be a DIY job I'm afraid...
  4. staygold67
    staygold67
    Jan 11, 2005
    3
    antrim
    woody, having the same problem finding suitable, 'livingroom/wife' friendly stand for my pj.I see your from n.ireland, so you could try 'wisebuys', they've a store in ballymena, which has some decent looking 'phone tables' and 'plant stands' etc, that may or may not be suitable.......but they're cheap and half decent looking, and around 80cms in height , which gives enough height to allow the pj to project over the back of a sofa.Hope this is helpful.
  5. WoodyAllen
    WoodyAllen
    Jan 19, 2004
    91
    Northern Ireland
    +4
    Good one - thanks for the steer. I've been making do with a naff coffee table; must revisit this.. regards
