Projector stand anyone?
Discussion in 'Projectors, Screens & Video Processors' started by verhaega, Mar 10, 2002.
  1. verhaega
    verhaega
    I'm looking for a stand for an MT3 that will fit up against the rear wall of my lounge, behind the sofa. So I need one where the shaft is at one end of the base and mounting plate.
    I'd also like to be able to remove the top part when not in use so it hides behind the sofa.
    Any ideas where I might find such a thing? I'm having no joy in trying to find something suitable.
  2. Walter mitty
    Walter mitty
    Aug 1, 2001
    232
    19
    Shropshire
    Hey there.............try B&Q or Homebase they do a video player stand it has a dual purpose cant remeber all it does but it`s cheap and hold it at either side and can be mounted anywhere, thats what I`m going to use I think
