Chaos Star
Bit of a projector newbie .
Just wondering if this sounds like a good projector specification.
Characteristics:
1800 ANSI Lumens
Resolution: XGA (1024 x 768)
Contrast ratio: 400:1
Input source: computer, DVI, HDTV, YCbCr, S-video, AV
Computer input: VGA (resized), SVGA (resized), XGA, SXGA (resized), UXGA (resized)
Video input: PAL, NTSC, SECAM
Audio system: 1W x 2
Properties:
Projection system: three-panel 0.9-inch LCD projector
Resolution (pixels): 1024 x 768 (786,432 dots x 3)
Brightness: 1800 ANSI Lumens
Uniformity: 85%
Lens: manual zoom (1.3X)
Focal length: 37.8mm to 49.2mm
Screen size: 30 to 300 inches
Throw distance: 1.64 to 16.35 meters
Projection type: front, rear, ceiling
Lamp life: 2,000 hours
Compatibility:
Horizontal frequency: 15kHz to 91kHz
Vertical frequency: 50Hz to 85Hz
Pixel rate: 12MHz to 157MHz
Color: 24 bits
Keystone correction: +/-15 degrees (digital)
Picture-in-picture (PIP): yes
Independent color control (ICC)
Computer input: VGA (resized), SVGA (resized), SXGA (resized), UXGA (resized)
Remote mouse: PS2 and USB
Remote control: multifunctional
OSD language: Chinese, English (other language can be added upon request)
Operating temperature: 5 to 35 degrees Celsius
Operation humidity: 35% to 85%
EMI and safety: UL, CE, FCC B
Power requirement: 100V to 240V, 50Hz to 60Hz
Power consumption: 210W
Dimensions (W x D x H): 297 x 248 x 96mm
Weight: 3.6kg (<8 lbs)
Is there anything missing on the specification.
Any help much appreciated
Characteristics:
1800 ANSI Lumens
Properties:
Uniformity: 85%
Compatibility:
Color: 24 bits
