Question Projector 'Sparkles' with Onkyo TX-SR875
Discussion in 'Home Cinema Buying & Building' started by GoodCoffeeCode, Jun 30, 2015.
  1. GoodCoffeeCode
    GoodCoffeeCode
    Dec 22, 2012
    28
    4
    Devon, UK
    Hi all,
    I have been using an Optoma HD151X for a few months now and have notice sporadic 'sparkles' on the screen. They look like lively white pixels that are randomly dancing across the entire screen. Recently they have been getting more prominent, but there seems to be no rhyme or reason as to whether they'll happen the next time I turn everything on.
    Here's what I discovered today whilst swapping HDMI cables...
    Amazon TV -> Onkyo TX-SR875 -> Optoma HD151X :: SPARKLES
    Amazon TV -> Optoma HD151X :: No Sparkles
    Amazon TV -> Onkyo TX-SR875 -> Panasonic LCD :: SPARKLES
    Some people have said that the projector will be more sensitive to any problems compared to the LCD. Is it possible that I have a dodgy HDMI board on the Onkyo?
    Any help most appreciated, thanks.
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,245
    +3,110
    So when you bypass the receiver you never get sparkles. My first port of call would be to look at the cable from the source to the receiver. HDMI send and receive chips have built in eq that expects the attached cable to be at least 9ft long. As the vogue is for short cables this is usually where problems occur. Swaping out a sub1m or 1m cable for a decent (not expensive) 2m or 2.5m cable often fixes issues like this.
  3. GoodCoffeeCode
    GoodCoffeeCode
    Dec 22, 2012
    28
    4
    Devon, UK
    Hi Gordon,
    All the cables running from sources to the receiver are of reasonable quality and 2m in length. I have just tried this combination:
    Amazon TV -> 2m HDMI -> Optoma HD151X :: No Sparkles
    Further information: when the Onkyo is starting and it projects the logo, there are no sparkles. Similarly, when I enter the Onkyo's setup menu, the sparkles immediately disappear - only to reappear again once the movie continues.
    This is driving me bonkers!
  4. Gordon @ Convergent AV
    Jul 13, 2000
    14,245
    +3,110
  5. andy1249
    andy1249
    May 7, 2006
    8,609
    +2,658
  6. GoodCoffeeCode
    GoodCoffeeCode
    Dec 22, 2012
    28
    4
    Devon, UK
    Not sure. Had a look through the menu items, but there nothing obvious re: processing or up-scaling. Where should I be looking?
  7. GoodCoffeeCode
    GoodCoffeeCode
    Dec 22, 2012
    28
    4
    Devon, UK
    Further experiment:
    Panasonic Blu-Ray -> HDMI -> Onkyo -> Optoma :: SPARKLES
    Panasonic Blu-Ray -> Crappy component video -> Onkyo -> Optoma :: No Sparkles
    Definitely feeling like an HDMI issue now.
  8. GoodCoffeeCode
    GoodCoffeeCode
    Dec 22, 2012
    28
    4
    Devon, UK
    Thanks Andy, but that issue seems to be related to audio and networking problems. Also, only looks like US warranty. I have a 'bought new' TX-SR875 but the serial number is just 10 digits, not the 16 that the web page is looking for.
  9. GoodCoffeeCode
    GoodCoffeeCode
    Dec 22, 2012
    28
    4
    Devon, UK
    BREAKTHROUGH!
    In the Onkyo menu I went:
    1 Input/Output Assign
    1. Monitor Out
    Resolution
    Changed resolution from 1080p to Through. No more sparkles!!!
    Have I not just dumbed down my screen image though?
  10. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,913
    The Borders
    +3,568
    No - your simply using the Display device to process the Source signal vs. processing in the AVR (and often reprocessing in the Display).
    Potentially you now have a better image (and no sparkles :)).
    Joe
  11. andy1249
    andy1249
    May 7, 2006
    8,609
    +2,658
    The threads on this issue , there are many of them across many sites, all refer to bad HDMI boards and sparklies, audio droputs, and simply no picture are all symptoms.
    Youve turned off the faulty component, and now you have a good picture.
    But you still have a faulty amp!
    You have just successfully identified the root cause, the amp is faulty.
    The choice should be yours as to which device does the scaling, once set to 1080p the amp should output that and the projector wont do any scaling, but the scaled output of the amp is faulty!
    Its not going to get any better...
  12. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,913
    The Borders
    +3,568
    As Andy says potentially a faulty AVR - contact Onkyo and seek a free repair (even if you don't necessarily need that Feature).
    Joe
  13. GoodCoffeeCode
    GoodCoffeeCode
    Dec 22, 2012
    28
    4
    Devon, UK
    Thanks everyone. Is the proceeding don't on the HDMI board itself? Would replacing that solve the problem, or is it handled elsewhere in the AVR?
