What settings/setup do you use with your projector when using Xbox?
I have an AE200 connected to a modified Xbox via component for progressive scan and I also use a Hoya filter.
I find 'dynamic' with a bit of contrast added to be best because the Xbox picture is known to be quite dull and murky.
I am still not totally happy with the picture as jaggies are still visible and the picture is not has sharp as I would like. I presume this is due to Xbox's limitations and that a higher resolution projector would not help much, but probably make it worse...
Any thoughts?
Any thoughts?
