Projector screen - quick easy and cheap
Discussion in 'LCD & LED LCD TVs' started by dUnKle, Aug 11, 2005.
  1. dUnKle
    dUnKle
    Jan 1, 2001
    13,372
    +1,322
    I have a Pansonic projector at home - the 100 model - had it since it was new but for last 10 months or so its had no use since moving the room round and getting a plasma
    I intend to put in back in use but need some help on the screen
    Previously I used a self built screen constructed of a wooden frame with some good quality black out material around it - this was then put up when needed - however thats no longer practical and I feel I need some kind of pull down blind - preferably something from B&Q etc if possible
    Can anyone recommend something suitable please
  2. dUnKle
    dUnKle
    Jan 1, 2001
    13,372
    +1,322
    sorry - in wrong place - can this be closed - sorry
