Projector & screen £800 - £1400
Discussion in 'Projectors, Screens & Video Processors' started by snoz, Nov 16, 2004.
  1. snoz
    snoz
    Oct 31, 2004
    128
    +4
    Looking to buy my first Pj in this bugdet if possible, new ball game to me.
    Have 10.5 ft from Pj to screen with projector being off centre by 3 ft.
    Can fit 16.9 82 inch diag screen above fireplace ceiling mounted.
    Would source Arcam 89 player + sky? if poss.
    Is it worth it in this bugdet, would be grateful for any feedback.
  2. mr ooops
    mr ooops
    Mar 4, 2003
    3,592
    103
    Hardwicke and Wotton
    +353
    800 to 1400 is a very nice budget :)
    got myself a screen from these guys www.drhscreens.co.uk delivered in perfect condion 3 days after ordering
    and for a pj i can highly recommend a z2, and im sure people will agree or maybe the z3 if you want to head towards the higher end of your budget, both can accomodate your lens shift requirements
    jason
  3. linnite
    linnite
    Nov 10, 2004
    699
    28
    Burscough, Lancs
    +48
    I ran my PTAE100 onto a white wall for 2 years 'till I finally bought a Beamax screen - in anticipation of getting a better projector where I wouldn't get away with it anymore.
    The point I'm trying to make is get the best PJ you can, shine it on a white wall if you have to and save up for a screen. You could regret scrimping on the PJ.
    You can get hold of a Sanyo Z3 or a Panny AE700 for 1250 or so and start your saving plan for the screen with the remaining 150.
  4. Kahless725
    Kahless725
    I got a Sanyo Z3 with free 6 foot widescreen scren for £1300 from stoneaudio.com, also did a free pixel check for me.
    Delivery was when they said it would be.
    Robert
  5. snoz
    snoz
    Oct 31, 2004
    128
    +4
    What cables would i need to run.
    The Pj would be mounted above sofa near ceiling if poss.
    How would i switch between veiwing sky ect from my widescreen tv to Pj
    Arcam dv89, Denon 3801, Sony FQ75, Kef eggs, Jm labs 714s
