Projector problem
Discussion in 'Projectors, Screens & Video Processors' started by foreveradevil, Feb 26, 2014.
  1. foreveradevil
    foreveradevil
    Jan 14, 2011
    36
    +4
    So here is my problem.. Newbie to the pj world by the way. Understand the throw distance etc and picked the pj and screen but the issue could be the room itself.
    Got a great Wall to project on.. 100" but at the required throw distance there is a light fitting potentially in the way. I have attached a picture of the layout... Does anyone know if the projection would or would not be impaired by the dangling light fitting? 1393448340932.jpg
  2. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,996
    UK.
    +3,447
    If you can get a clear view of the lens from each side of the screen when looking back at where the projector lens is going to be, you should be fine.
    Gary
  3. SteveCritten
    SteveCritten
    Aug 13, 2009
    10,980
    Caistor Lincs
    +4,671
    Some measurements might help too.
  4. totters1972
    totters1972
    Mar 26, 2007
    235
    Nr. Bath
    +19
    I had to change the light fitting in my room to a shallow 3 way spotlight, so don't be put off.
  5. mojogoes
    mojogoes
    Remembered (1961-2016)
    Oct 12, 2007
    10,469
    Faraneverland
    +1,984
