M
Mr fuse
Okay need some help please!
Looking to buy my first projector im on a tight budget and have decided on the epson tw-10.
My problem is the positioning of the projector so before I buy one I would like to check what the experts think.
Okay ceiling mounted is out of the question and unfortunatly so is a shelf but I still really want to get a projector so I have two options left I have a wall unit that it can sit on but this means that the projector will sit about 3ft wide of where the centre of the screen will be is this out of the question?
The other option is for it to sit on a table in front of the sofa which isint ideal but what can you do? Any advice please?
