Quantcast
Projector PAL 50hz issues.
Copperge
Hi all,
Just bought myself a new projector (philips ppx 1230) and have hooked up my xbox to it using a component cable. However in order for any display to be shown (Sound isn't the issue here) the xboxs display settings to PAL 50hz. meaning that i can only play certain games.
Is there anyway to allow the projector to display the xbox on PAL 60hz (considering the projector apparently supports PAL 60hz)?
Muchas gracias :)
Badger0-0
It seems to me that it only supports 60hz via the VGA socket.
Hence I don't think you can do anything about it, but could be wrong.
Indiana Jones
Does the projector not have any other inputs? as composite is the worst possible connection you can use.
