projector paint for wall
Discussion in 'Projectors, Screens & Video Processors' started by yamyamgaz, Jun 30, 2017.
  1. yamyamgaz
    yamyamgaz
    Jun 30, 2017
    wolverhampton
    hi everyone
    im looking for advice on paint for projecting straight onto a newly plastered wall.
    the room in question has been built with projecting on to the wall in mind. screen size will be around 110 inches wide with options to mount a new projector 3-3.5 meters away.
    i havnt yet decided which projector to buy but im looking at an optima or ben q under 600 poundish which needs to be suitable for gaming, movies and sports (its a man cave i suppose)
    i havnt decided on decor for the rest of the room and the lighting will be completely controllable as its a seperate building at the bottom of the garden
    onto paint ive been reading afew threads on the forum but they all seem quite old so i was wondering what the latest advice is on which paint to get,
    so far ive seen the aaa and gs2 mix has been highly recommended but i was wondering if anyone had used the following.....
    Create your own home cinema
    so in summary any advice on decor colours ie would darker colours be more suitable, projectors and screen paint would be much appreciated.
    thanks in advance
    gaz
  2. daredevill
    daredevill
    Jan 8, 2005
    539
    46
    +180
    I used the black widow screen mix when I had a lighter coloured room. Results were great. It dries a greyish colour so you could make it a feature wall perhaps?
  3. meva
    meva
    Feb 20, 2001
    353
    cornwall,uk
    +14
    I just made myself a fixed screen with black widow paint and find it excellent. Although if you do have total light control plain white may be the way to go.
  4. ELV
    ELV
    Jun 5, 2001
    690
    Up in the proper north
    +11
    Second the white if you have Blackout conditions. I have a 120inch screen and it looks great. Painted the borders black and have stone velour panels for 2.35 films.
