Projector Opinions
matblack
Hi guys
I have been offered one of these for £450
http://www.projectorcentral.com/Sony-VPL-X1000U.htm
Can anyone tell me if this is a good deal?
It will be going in a cellar conversion with a 3.5m throw to the screen, light levels will be very dim for viewing and it will occationally be used for video gaming. Seating will be at about 3m.
The seller seems very genuine and the bulb is almost new.
Although it will be XGA I will want to run in widescreen for DVD, is this a problem?
The small number of reviews I have seen seem very favorable but there arn't many around.
MB
Oakleyspatz
If this is your first projector, then I think you will be very pleased indeed with it. It has a very bright image and an excellent resolution. What it will lack is a high contrast ratio and it is only a 4:3 ratio not a 16:9 ratio. What this means is when watching a 16:9 image, the size will be smaller than a 4:3 image ( which is the opposite of a 16:9 ratio projector) Because of the high resolution, this should not be a problem as you can zoom the image bigger.
Sony has always made superb LCD projectors and although this model isn't a dedicated Home Cinema one, I'm sure it will carry out the duty admirably.
matblack
Sounds good.
Yes it would be my first projector and I would be running it off a DVD player or my PC.
Do you have any idea on how big a picture I can expect off the 4m throw? It would really help to sway me if I knew :)
Ahhhhh you mention zooming, does this mean I will be able to adjust the picture size without moving the projector closer to the screen? That probably sounds like a really nooby question
MB
Oakleyspatz
You would get an image of between 1.81m and 2.16m across depending on the zoom you have. Yes, you have a manual zoom ring around the lens. turn this and the image zooms in or out making it larger or smaller all without moving the projector a bit!
PJTX100
Zooming is great.
When people come to see the TX I I love to zoom to the minimum image and say "hey this is what a 52" 4 grand plasma would look like :) "...PJ
OneEyedStuart
PJTX100 said:
Zooming is great.
You're evil, I like it :rotfl:
KH
matblack
:thumbsup: Thats HUGE!
Hehe, I've told the guy I'm going to buy it, will have to wait and see what its like but at that price with a new bulb it seems like a good deal and its supposed to be built like a tank. I get a lazer pointer in the remote too :cool:
Now to start thinking about moving my old Marantz AV Amp and speakers to the basement and getting a new setup for upstairs. :devil:
MB
