Projector only £260
Discussion in 'Shopping, Deals, Discounts & Bargains' started by tartan_guru, Oct 23, 2004.
  1. tartan_guru
    tartan_guru
    Nov 17, 2003
    154
    London
    +17
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Definition – 480*234
    8 hours continuous working time
    Life of light – 1000H
    Load of crap mate...............
  3. tartan_guru
    tartan_guru
    Nov 17, 2003
    154
    London
    +17
    I'm aware that it's not the highest quality of devices, however it may just be the ticket for someone who wants to play games on a big screen and isn't worried by by the quality (i.e bang for buck).
    I'm more intrigued by what technology it is using, I assume it probably uses an handheld LCD TV type panel and a halogen type bulb
  4. Promised Land
    Promised Land
    May 4, 2004
    215
    16
    The Thin Line
    I understand what you're saying about occasional use but as Horny Dragon pointed out,the resolution is pants.They quote a maximum image size(ideally)of 48 inches on that site and as is the case in these matters,it's probably lower than that really.I'd say a much better option would be a used Panasonic AE100 or similar.You could pick this sort of thing up for another £100-£150 on top of the price of what you're looking at there.Try a wanted ad in the classified section of this forum if I were you.
