Projector mounts ?
Discussion in 'Projectors, Screens & Video Processors' started by karkus30, Mar 22, 2005.
  1. karkus30
    karkus30
    Jul 29, 2002
    13,991
    +1,261
    Wheres the best place (cheapest) to buy a ceiling mount for my Sanyo PLV 30 PJ ? I need a 30 cm tube or their abouts. Its only for home use so security is not an issue.
  2. OneEyedStuart
    OneEyedStuart
    Oct 12, 2003
    4,881
    Falkirk, Scotland
    +842
  3. karkus30
    karkus30
    Jul 29, 2002
    13,991
    +1,261
    They no longer deal with the general public :( which means going to one of their dealers, so your having to pay a middleman, which means all the mounts are at a similar price. Its a bit daft that they are advertising on what is ostensibly a public forum.
  4. OneEyedStuart
    OneEyedStuart
    Oct 12, 2003
    4,881
    Falkirk, Scotland
    +842
    God, never knew that. Only bought my mount a few months ago as well.
    KH
  5. stripe
    stripe
    Apr 7, 2004
    1,241
    Scotland
    +123
    I was quoted the same price last week from the "middle man" as I was from LMP late last year, so there has been no price leap. :thumbsup:
  6. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,464
    Surrey. UK.
    +2,114
    If you're OK with a little DIY, the MK2 speaker bracket here, combined with some 6mm MDF should do the trick:
    http://uk.geocities.com/g.lightfoot@btinternet.com/ht1000.html
    It will allow the pj to rotate, and tip left and right. If you want it to tip forward/back, then you can either shim the bracket at the ceiling, or add-in the small tube from the other bracket (there are two in the box). You will need another bolt for the tube mod:
    http://www.avforums.com/forums/showpost.php?p=1076544&postcount=56
    It extends from 10 to 14ins IRC, but more details are in the thread above that I've linked to.
    Gary.
  7. karkus30
    karkus30
    Jul 29, 2002
    13,991
    +1,261
    Thanks for the help, I'm sorted now, just the drilling, sawing and screwing (ooh matron) and I will have finally completed my HC installation. Proper dedicated HC room, finally :rolleyes: :smashin:
