thanks alebonou,the peerless looks a good system,but £130 just for the base then as far as i can see you have to buy the ceiling plate seperate and then the adjustable pole seperate,seems overpriced to me,
it's not too complicated to lock an adjustable bracket,i'm sure i can find a mount that will do the job for a lot less,
i agree the system looks good and understand your happy with it,but i struggle to pay £130 quid for an adjustable bracket,i have had 4 projectors over the last 18yrs so setting them in position every 4 years or so i don't think the quick release system is something i miss.
Which is why suggested the peerless or strong. Both not only adjustments to precision ... they also lock down the settings. Ie hold them .. to point can exchange the entire projector and still hold setting on the peerless.This latest mount i bought a couple of years ago does the job of supporting the projector,but the locking system on the mounting bracket is not the best,it does move slightly if I'm cleaning dust off the projector,hence wanting a better locking mount,even though its not much of a problem.
