Hi Guys,
I've got a query on mounting a projector (thinking of the Epson 3200 which is 7.3kg) upside down on either a wall or ceiling mount.
The Epson uses M4x9 screws, and it has 5 holes to screw into, however the wall & ceiling mounts that are at the top of my list only have 3 mounting points on them. Will 3 x M4x9 screws hold the projector safely, or do I need to be looking exclusively at mounts with 4 (or 5!) mounting points?
The last thing I want is having some massive bolts in the wall to make sure it doesn't fall off only for the unit to fall off the mount itself!!
Mark
Mark
