SeanRo
I'm doing the calcs for my first projector purchase and would like help on what specs I am looking for. Here are my proposed angles:
Projector angle to top of screen: 6 degrees down from horizontal
Projector angle to bottom of screen: 23 degrees down from horizontal
Projector distance from screen: 4.3m
Eyes angle to top of screen : 16.5 degrees up from horizontal (I read that >20 degrees causes fatigue)
Eyes angle to bottom of screen : 11 degrees down from horizontal
Eyes distance from screen: 3.2m
Screen width: 3.2m
Q. if I want the projector to switch from 16:9 to 2.35:1 on detected content, what projector feature should I look for?
Q. if I want the projector to shift the image down as in my sketchup, what do I look for?
Q. are these reasonable angles/distances for a projector to work with?
Thanks in advance!
Screen width: 3.2m
Thanks in advance!
