Slinkywizard
I'm replacing the lamp on my Sony VPL-VW260ES today for the first time. This is after 2,500 hours in 'high' lamp mode. Though the lamp is rated to last 6,000 hours, unless it's entirely my imagination the picture is starting to look a bit dim, and there is some yellowing in the whites.
It's a bit rule of thumb really. I was never going to wait till the projector tells me to replace it because by that point I would have lost so much performance I would have been making do with sub-par images.
I have a lux metre and will post some before and after numbers here once I've taken the measurements tonight. Hopefully, creating this thread and sharing stories can help others determine whether they should replace their lamp or not, even when the old one still, technically, works fine.
So, to other projector users. What make/model do you own? What interval, in hours, do you allow to pass between replacements? What sort of performance gain do you see? Does anyone leave their lamp in till the projector actually tells them to replace it?
This is my first experience of this, so would like to hear from some more experienced people and how they go about it, and in doing that, hopefully create a thread that will inform others.
