Mallardo
Hi all
I have a 13 year old Sanyo PLV-Z2000. I bought it second hand about 4 years ago and have been really happy with it. It is working fine however the lamp now has has about 1800 hours on it and I am wondering whether it would be worthwhile replacing it. The projector hasn't indicated that it needs changing yet, but I think it may do so quite soon as I think it is rated for 2000 hours.
I have read that bulbs dim over time but this can be quite hard to tell from a user perspective as it is very gradual. I have been using the A2 lamp mode instead of ECO for a while now as I have noticed the image in ECO seemed to be getting a bit dull . I don't want to switch to full power as the fan noise gets on my nerves, it is pretty much silent in the other modes. Currently the image is pretty good on A2 in a dark room.
Does anyone know if replacing the lamp would be worth it? Would the difference in picture quality would be noticeable and worth the outlay of £100?
