Projector issues
Discussion in 'Projectors, Screens & Video Processors' started by Frankeh, May 27, 2005.
  1. Frankeh
    Frankeh
    I still don't know yet if I would go with a Projector... my room isn't big: 4x3 m = 10x13 feet
    A dark room isn't a problem for me, I always game in a full dark room.
    If I would go with a projector, the max. distance I can sit away from the screen would be 10 feet.
    The projector will be used for 95% gaming purpose, the other 5% will be for watching movies.
    A full field of vision (= big screens) can't be good for gaming (I THINK) because you don't know where to look at + less concentration because of the big screen.
    Maybe just buy a smaller screen? (can you give me measures for a good gaming screen if you're 10feet away of it) I could shrink the image down... is the image quality fine than?
    Last issue: I'm not buying a projector because I want a friggin big screen, I would buy it because it's not that expensive + easily HDTV ready in Europe so another question is: when I'm not buying a projector for the size, should I better go with a LCD?
  2. inzaman
    inzaman
    Dec 16, 2002
    7,962
    Derby
    +1,026
    I have a Z2, i sit 10 feet away from the screen which is 6 foot wide and for me this is perfect. I did have a 7 foot wide screen but was constantly looking left and right as i could not get the entire image into my field of vision.
    I love playing the xbox on the big screen it is amazing and i could not now go back to playing it on a TV, infact for me it makes me concentrate more as i am just focussed on the image.
    For gaming i would have said go with lcd at the same price point as dlp just because of the higher resolution and the consoles due soon all seem to be supporting hidef at 720/1080, but with the arrival of the Benq PE7700 this confuses the issue somewhat.
  3. Geesus
    Geesus
    Dec 23, 2003
    2,363
    116
    +754
    Bear in mind that the benefits of a projector are not *just* size - I find the actual picture quality from my Z3 far better than my old Tosh 36ZP38 PF2 CRT - no green streaks in darker scenes, and also the benefit of having equipment that will handle increased resolutions better than most (if not all) televisions.
    I also notice far less artifacting on DVD's, and of course geometry will be excellent...
  4. Frankeh
    Frankeh
    Is the BenQ 7700 really that good? It's a bit over my budget.. + I have to buy a screen too
    (I can project it onto my wall, but it has a warm orange colour)
    @ bold: I don't get it.. you're saying you would advice me to buy a LCD because of the higher resolution AND the fact next-gen consoles will support HDTV.. ermh that counts for Projectors too huh? they also support 720p / 1080i you're confusing me. :p
  5. Boozley69
    Boozley69
    May 27, 2005
    19
    I have an EPSON EMP-TW10H LCD projector. I sit a couple of meters away from the screen and the projector is temporarily sitting on the table infront of me. It projects onto a magenta (red) wall and the image is flawless! It is 80 inches diagonal and can go bigger/smaller. I play xbox live on it and have never been better. DVD picture is amazing. I am simply amazed by this projector and got it for a mere £555 From EBuyer.
    http://www.ebuyer.com/customer/prod...2hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=62929
    Its top quality for a very cheap price. Would highly recomend.
    Boozley
  6. cyberheater
    cyberheater
    Apr 3, 2003
    3,225
    Scotland
    +179
    Whatever you get. Make sure it's got hdcp to make it future proof.
  7. mr ooops
    mr ooops
    Mar 4, 2003
    3,657
    103
    Hardwicke and Wotton
    +349
    he means look at a lcd projector like sanyo z2 or z3, and not at a dlp projector :)
  8. inzaman
    inzaman
    Dec 16, 2002
    7,962
    Derby
    +1,026
    Yes all pj's can support 720/1080 but they dont all have high res panels, hence why i was saying that for gaming imo i would go lcd as at the same price point as dlp. With LCD you will get a 1280x720 panel as opposed to DLP where for the same price point you will get a 854x480 resolution panel.
    The DLP will no doubt have a higher contrast ratio though.
  9. Frankeh
    Frankeh
    I'm sorry, I thought you meant "LCD" as in "LCD TV's" not "LCD Projector" I did some google work and now I learned the different kind of projectors: LCD, DLP, LCOS, ...
    I don't see why LCD PJ > DLP PJ for gaming? I read some articles, they said DLP has all the advantages of the LCD + better black + better colours + less pixel structure
    the fact colours & black are important.. I don't see why LCD projectors would be better? because the fact LCD have higher resolutions? But when I play a game with 720p HD for example... doesn't the projector automatically go to that resolution?
  10. Geesus
    Geesus
    Dec 23, 2003
    2,363
    116
    +754
    Games + DLP Rainbows = bad!
    Of course if you don't see them then great, though I'd recommend a demo first.
  11. stlic
    stlic
    Feb 17, 2004
    762
    +19
    It won't go to that resolution if your projector doesn't support it. True 720p DLP projectors, until recently, were more expensive then their LCD counterparts so it was trade off. DLP may have better blacks but lower res and rainbow effect; LCD can suffer from chicken mesh. Next Gen consoles will support 720p+ out of the box and I'm sure having a projector that supports this res natively will be beneficial. No doubt these console will be backwards compatible with SDTV though.
  12. Frankeh
    Frankeh
    most DLP projectors with a price range of 1350£ support 720p/1080i don't they.. ?
  13. inzaman
    inzaman
    Dec 16, 2002
    7,962
    Derby
    +1,026
    Yes they do, but if you are outputting a 720 image the pj will have to downscale this image to fit the native resolution of the panel.
  14. Frankeh
    Frankeh
    so for gaming on 720p it's better to buy an LCD because of the higher resolution it has?
  15. Frankeh
    Frankeh
    anyone?
  16. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
    To boil it down, you currently get more resolution for your money with LCD PJs, though the gap seems to be narrowing.
    If 720p applications are important then, unless you want to shell out more on a WXGA DLP, an LCD PJ may be a good option for you.
    It's not worth debating the picture quality differences, we could be here all day. Suffice to say you'd be impressed by any modern PJ, DLP or LCD...PJ :)
  17. Frankeh
    Frankeh
    Wxga Dlp?
  18. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
    I you've
    "read some articles, they said DLP has all the advantages of the LCD + better black + better colours + less pixel structure"
    then I'm sure you can find something on WXGA...PJ :)
