Projector Inputs for gaming
Discussion in 'Projectors, Screens & Video Processors' started by Frankeh, May 29, 2005.
  1. Frankeh
    Frankeh
    I was googling for the back of the projector = the inputs.
    I was looking at the back of the Panasonic PTAE 700:
    http://www.discounttv.co.uk/ptae700rear-Large.jpg
    And the Sanyo Z3:
    http://www.avclick.co.kr/upimg/Z3_ETC.jpg
    I was wondering.. I use RGB on my regular TV, is this possible on projectors too? I see no SCART input on the Sanyo Z3, though.. I see one on the Panasonic, does that scart input on the panasonic have the ability for RGB? Because I know not every scart input is "RGB ready"
  2. Kramer
    Kramer
    Yes, the AE700's scart connector is RGB enabled.
    :smoke:
  3. Frankeh
    Frankeh
    so the Sanyo Z3 isn't compatible for RGB ?
  4. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,303
    71
    Liverpool: European Capital of Football 2005/2006
    +76
    jesus you are going through the threads. about 4 or 5 in 2 days :devil:
    for the Z3 i assume you could use a Scart RGB to component converter to connect. why not just connect consoles with component ? especially xbox as then you could soft/hard mod to allow 480p/720p/1080i and 480p is a remarkable step up from 480i etc cant actually remember off hand what pal is 576i ????
  5. Frankeh
    Frankeh
    photo?
    because PS2 & XBOX are not HD compatible in Europe so I'm nothing with component.
  6. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,303
    71
    +76
    we are in europe in case you hadnt noticed the base of this forum is UK. i have a PAL xbox and PS2 both connected to my High Def projector by component
  7. Frankeh
    Frankeh
    how do you connect your ps2 & xbox to High Def projector??
  8. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,303
    71
    +76
    dont like to quote myself but ive already posted ;) :smashin:
  9. Frankeh
    Frankeh
    Sorry I forgot to add something in my previous post: "how do you connect the component with your consoles?" component are 3 colours right? blue, green, red
    through some adapter? (if so please link me to a photo)
    because you can't connect through component with the standard cables...
  10. seb4213
    seb4213
    May 15, 2005
    25
    3
    You can buy a MS high defintion pack that allows Xbox to component :D
  11. mutley
    mutley
    Jul 28, 2002
    445
    Portugal
    There are component cables to PS2 and Xbox you can buy...
  12. Tyjay
    Tyjay
    Apr 16, 2004
    7,481
    Bedlington
    +2,945
    get xbox\gc\ps2 compnent leads from playasia.com
