projector help please
jasonjbj
Established Member
Joined
Aug 11, 2003
Messages
653
Reaction score
19
Points
113
got the new pansonic
not got a proper screen yet
piture seems to be a little slanted
eg 80 inch across at top
75 inch at the bottom
is there anyway of changing this if so any help would be a great!
also whats the besy screen to buy?
thanks jason
have you tried the keystone? it sounds like the projector is simply not 100% level.
best screen on a budget is a home made ;)
ad
not tryed keystone yet
got told makes piture worse
thought there might be another way around it
it will distort the image so yes, it will degrade the image. But if you have a trapezoid screen that you cant adjust by moving the projector itself, then keystone is your only way. Every chance you wont notice any degradation unless you are 1:1 mapping and looking closely.
ad
on a tilt
at the moment
might have to keep playing around with it
but wow !!its amazing!!
are draper screens any good??
the tilt is the reason for the shape.....
draper are reasonable from comments on here
ad
sorted!!
thanks for help
any info onscreens will be great
theres that many out there
are manual screens easy to use?to they have a pull down handle?
this is what i need
celing fixed 36 inch blackdrop
then 45 inch down and 80 inch across piture
only found draper what had backdrops more than 12 inches
any body now cheaper ones let me know!
if you need a screen man to help, pm retro since his company is involved in this area
ad
Try DRH screens, I've just ordered one from them with a bigger top border, £20 more than standard price and only take a couple of days to make and ship, rather than a few weeks like some others i've rung up.
Try doing a search on the forums for nexnix screen,took delivery of my 7ft electric screen 2 weeks ago£470 delivered.Excellent screen and the picture is great of my panny AE200.
The BIG PROBLEM With Your Home AV System EXPLAINED
Back
