Projector freezing while locking on a source signal
Discussion in 'Projectors, Screens & Video Processors' started by crion, Sep 19, 2004.
  1. crion
    crion
    Jun 6, 2004
    23
    Hi, I've had a Sim2HT300Plus for almost 2 years now, but today my pj started acting weird. When I try to view sources on my RI2 it changes to the input RGBS 15KHz for example, small info box goes blue and then the projector is in freeze mode and I can't do anything except turn it off on the backpanel. I'm running 2.36 firmware and I have never experienced this before. I also tried the DVI input and it works if I power up the projector with it, but if I change resolution like going from 1280*[email protected]0hz to 1280*[email protected] the screen just go black and I can't do anything except turn it off on the backpanel.
    Anyone else had an experience like this? I will contact my dealer on monday for a repair as it should be covered by warranty.
