projector for small room
Discussion in 'Projectors, Screens & Video Processors' started by rab4169, Feb 24, 2005.
  1. rab4169
    rab4169
    Dec 12, 2004
    533
    i have a small enertainment room upstairs in my house , i have a 6ft screen with a sharp lcd projector , i sit about 8 foot from screen as that is as far back as the seat will go , this is connected to a pc . the problem is i see the wire effect on the screen , would upgrading to a dlp stop this or am i stuck with this in such a small room
    thanks
    robert
  2. Benrudd1
    Benrudd1
    Jan 19, 2003
    961
    Pembroke Dock
    +66
    I personally would recommend a panasonic projector. The smooth screen technology works really well.
    I have an ae300 set about 7' from a 5.5' diagonal screen, i'm also sat directly under the pj at about 7' from the screen and cannot see any pixel structure at all.
    The panasonic ae300, ae500 (both discontinued) and the new ae700 all use this technology.
    Hope this helps
  3. rab4169
    rab4169
    Dec 12, 2004
    533
    thanks will keep an eye on ebay for a 300
    thanks
    robert
