Projector for a Motorhome
Discussion in 'Projectors, Screens & Video Processors' started by the_sanguine, Nov 6, 2005.
  1. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,176
    38
    +7
    Hi. I know nothing about projectors. I have always been a bit put off by the crap pictures pubs seem to get when showing the footie. I'm sure they can produce a decent picture when properly set up though....
    Anyway, I'm looking to put sky in a motorhome and am investigating what kind of monitor to go for.
    One idea is to get a white blind over a side window and use it as a screen mounting the projector in a cupboard above the opposite window. Any thoughts on that?
  2. stu mcc
    stu mcc
    Nov 13, 2004
    647
    28
    +40
    I would've thought that the throw would only be about 2m max, don't know if there is a projector capable of doing that especially with ambient light conditions in a motorhome. Maybe your best bet would be a plasma or lcd for that kind of situation? It seemed to work ok for Max and Paddy!
    Stu.
  3. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,033
    Harrow, NW London
    +600
    as i just posted in another thread, What Hifi did show off a new projector the other month that can project a big image (7 or 8ft) from quite close to the screen (as in a few feet i think it was) works using mirrors......i think they said the image was pretty good...
    oh wait, it might have been What Projector, not What Hifi...doh....
    better edit my other post in a different thread...lol
  4. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,033
    Harrow, NW London
    +600
    cant remember who made it tho or how much, if i can find the mag i'll post again...
  5. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,176
    38
    +7
    I probably only need an image about the same size as a 32" screen because that would be about the size of the blind on the opposite window. Otherwise, I'll probably have to go down the LCD route.
  6. Maff et1
    Maff et1
    The Tosh ET-1 has a very short throw. 32in diagonal from .75m (30in), it's also cheap at about 380.
    http://www.pvp.toshiba.co.uk/consumer/projectors/products.nsf/files/et1/$file/et1-B.pdf?openelement
    Fan noise might be an issue in a small environment like that.
  7. mrmcdean
    mrmcdean
    Jun 25, 2003
    733
    +27
    Is it possible to alter the size of an image - smaller or larger by using special lenses ??? Sorry if its a stupid question :suicide:
  8. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,176
    38
    +7
    That was my next question. If I could mount it in a cupboard above one window and throw onto a screen that doubles as a blind on the other window, that would be great.
    If the projector is above the screen, how does it compensate so that you still get a rectangular picture and not like a triangle with the top cut off?
  9. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,176
    38
    +7
  10. Menace
    Menace
    I know Hitachi have a PJ that will throw a 76 inch diag image at 1.9m (cant remember the model sorry) Its is HDTV compatible (aparantly). I think it sways towards the presentation side of things with higher lumens but is still a pretty good all rounder, just wish I could remember the model.....dammit.
    Saying that....if your not too bothered about "dedicated" home projectors, most makers presentation PJs have short throws.
    Just depends on how indepth you are to detail
  11. ji_
    ji_
    Dec 1, 2002
    57
    in transit
    Too little space, too restrictive on where you can mount the PJ, too noisy in such a confined space - go for a cheap LCD. The other althernative might be to mount it externally and project onto the side of the van!
    Charge a few quid for other campers - make a fortune :)
  12. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,176
    38
    +7
    I must admit, I did think of that when the world cups on next year!
    I did think if I get a projector, I could take a screen with me though and put it up in the awning.......OK till next night when I pop out for a beer and then come back and find out that the van's been done over
