Projector for £300 - £400
Akirru
Thanks for your quick reply.
Yeah its just for movies. Is it possible to get a 1080p projector in this price range? I'm happy with 720p but I was just curious.
This looks like a good deal for the money though :)
EDIT: Could you recommend a decent projection screen to go with it? That isn't too expensive of course.
Andy
kbfern
You won't get a 1080p new or second hand at this price level,the cheapest second hand would be around £550 and new £750-£800.
As Steve has said a white wall could be used and failing that a pull down blind from IKEA has been used by some folks which costs approx £25.
Proper screens cost from £80 and up depending on size.
Trending threads
