projector distance
Discussion in 'Projectors, Screens & Video Processors' started by Geoffc10, Mar 11, 2002.
  1. Geoffc10
    Geoffc10
    Im planning on making my spare bedroom into a home cinema. its 11 1/2 foot by 8ft. Want to get the LCD Sanyo plv30 and a 5ft screen.
    If i sit 10ft away from the screen, will that be too close to view the film??.
  2. Shockabuku
    Shockabuku
    Mar 5, 2002
    1,807
    Oxfordshire
    +167
    Hi Geoffc10. In theory, you should be fine. The general rule of thumb is to sit between 1.5x & 2x screen width away, although some break these rules quite happily! You may want to check out the good old Projector Central projection calculator to plan where you can put the projector.
    I gotta say it though...have you considered the Panasonic PT-AE100E? Definitely worth a look if you're in the price range of the Sanyo you mention. 16:9 native format & pictures to die for (at the price - £1400). Search this forum for looooads more info. There, I feel better now :D
  3. Geoffc10
    Geoffc10
    Thanks for the info. I'll have a look at the Panasonic model. Only reason for the Sanyo was that it got a good write up in HCC (Best Buy)
  4. Jones_Rush
    Jones_Rush
    Geoffc10,
    If you only sit 1.5 foot from the wall, how will you be able to use a center surround (ES/EX) ?, there isn't enough space behind you to fit a speaker.
  5. mysphyt
    mysphyt
    10 feet from a 5 foot screen sounds about right. Gives you a 28 degree viewing arc, which is right in line with SMPTE recommended viewing distance/screen size recommendations (for cinemas, but since that's what we're trying to build....)
    From viewing distance calculator.
  6. Timh
    Timh
    Sep 14, 2000
    5,267
    3
    3
    Altair-4
    +339
    Geoffc10
    The Panasonic is to be reviewed in the next Home cinema choice mag, you can't always trust the review's though.
  7. Shockabuku
    Shockabuku
    Mar 5, 2002
    1,807
    Oxfordshire
    +167
    I agree with Tim....ignore the mags & listen to us lot :D :D
