Projector choice
Discussion in 'Projectors, Screens & Video Processors' started by chilly, Jan 12, 2004.
  1. chilly
    chilly
    Hi all, I am currently stuck between the Epson EMP-TW10 and the Hitachi PJ-TX10, the Hitachi gets slightly better review results but has been around longer while the Epson comes with a 3 year next day warranty which seems appealing, my concern is that my house has high ceilings, I need to ceiling mount but can only bring the projector down to a level where the lens in level with the top of the screen, the Epson has electronic keystone while the Hitachi has manual and electronic adjustments, the ceiling mount I am considering also has three way adjustment, am I reading into this too much or is this a problem.
  2. Seahorse
    Seahorse
    Jul 28, 2002
    141
    Southampton, Hants
    +3
    Get a longer ceiling mount as Keystone degrades picture quality. The 3 way adjustment will allow you to fine tune the set up...
  3. Mr Sparkle
    Mr Sparkle
    Oct 17, 2003
    212
    Chilly,
    I have the PJ-TX10...the manual lens shift (vertical and horizontal) gives you soooooo much versatility with the placement/mounitng of the projector. Optically, I'd guess the Epson and Hitachi are about the same. If you have mounting issues, I'd go the for PJ-TX10.
    Hope this helps.
    Mr Sparkle
  4. chilly
    chilly
    Thanks guys, I have now ordered the Hitachi along with an LMP mount, looking forward to it, cheers.
  5. RajUK
    RajUK
    Dec 18, 2001
    157
    Reading
    +6
    I've a pjtx10 too
    along with a projecta screen (not short hand, the company really is called projecta)
    xbox and sony dvpns730 on component input is fine with it
    next is a few years wait for an affordable 3-chip dlp, heh
