Projector Angle help
Discussion in 'Projectors, Screens & Video Processors' started by MrCoopz, Jul 5, 2002.
  1. MrCoopz
    MrCoopz
    Jun 28, 2002
    1,107
    63
    +115
    i have a problem i have to put my projector on shelf on the wall, but i need to know if its ok to tilt it from the back (as shown in picture)
    [​IMG]
    i dont know if its ok to turn it upside down on the shelf but then i cant get to the buttons and i cant mount it on the ceiling because i have a ceiling fan
    BTW my seating is under it so i cant put it any lower
  2. ChrisAllenFiz
    ChrisAllenFiz
    Jun 14, 2002
    819
    +17
    As far as I know you can, but you will have to use keystone correction, which will probably effect the picture quality. Anyone else care to elaborate on this? (I`m just a beginner too)
    Chris
  3. General Skanky
    General Skanky
    Jul 28, 2000
    4,251
    71
    Colchester
    +44
    Which pj is it? Mine is just above my seats using a bit of Keystone to correct the image. The pic quality does suffer with 'any' correction. Mine is lifted a touch at the back to lower the image on screen else it would be too high. It's all compromise, unless you do go for the ceiling option.
    You can see my set up in my links.
  4. ChrisAllenFiz
    ChrisAllenFiz
    Jun 14, 2002
    819
    +17
    I`m a bit confused as to why you didn`t mount the pj upside down on the shelf and put it higher up, or was there something in the way?
    Chris
  5. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,782
    Cheshire
    +109
    Mr Coopz,
    Putting the projector on the shelf as in your picture is going to create a problem with focus as well as keystone.
    Do you have a remote control for the projector? Is the projector capable of being inverted?
    If the answer is Yes to both, then put the projector on its back and use the remote for set-up. If you need access to the projector buttons think about cutting a hole in the shelf.
    Regards
  6. MrCoopz
    MrCoopz
    Jun 28, 2002
    1,107
    63
    +115
    General Skanky its a PTAE100
    if i put it upside down would and switched it to "ceiling" would i lose quality then??
  7. ChrisAllenFiz
    ChrisAllenFiz
    Jun 14, 2002
    819
    +17
    I don`t think you would lose quality. The only issue might be cooling, but I can`t see it being a problem, I intended to put my AE100 upside down on a shelf when it arrives, so I hope its not a problem! :)
    Chris
  8. General Skanky
    General Skanky
    Jul 28, 2000
    4,251
    71
    Colchester
    +44
    I never actually thought to put it upside down!:rolleyes:
    I will try it now.
    Chris is right, focus and keystone is out as it is now, but not badly so and prog scan is really good. Only the sky S Video feed is 'off'.
    Switching it to ceiling is no problem, it's just an inverted image, that's all. I'll let you know tomorrow how I find it. Cooling won't be any different as it's a rear vented system.
  9. General Skanky
    General Skanky
    Jul 28, 2000
    4,251
    71
    Colchester
    +44
    What I have done is take away the wedge at the back. Picture quality does reach maximum and it's very good indeed on Sky, S Video. However, it projects a bit high onto my screen.
    I don't think I'll turn it upside down, it'll look odd and I won't be able to get at the buttons on top. I'll have to think about dropping the shelf height. Butl ike I said, it's all a compromise. I'm not going to ceiling mount it, so it's either a higher image or drop it down again with the wedge and lose some pic quality/focus.
  10. MrCoopz
    MrCoopz
    Jun 28, 2002
    1,107
    63
    +115
    General Skanky whats ur picture like on sky??
    Can u tell me ur settings and how u have it connected??
  11. General Skanky
    General Skanky
    Jul 28, 2000
    4,251
    71
    Colchester
    +44
    OK.
    RGB converted to S Video.
    So S Video to pj.
    Then just turned the sharpness down to -8 to get rid of the cross hatching and that's it. Brightness etc just tweaked until it's ok for our room. Used AVIA and Platinum discs for set up, but then 'adjusted' for my taste.:)
    I personally think the picture is great.
    I've always had the slight defocusing too, but now going back to a 'non error/keystoned' pic, it's really good.
    Depending on who you listen to and how much money you want to spend, it's as good a solution as any. I'd like to buy a unit that gives me prog scan component or equivalent for sky etc, but it's always cost vrs. convenience vrs connectivity. So for now I am more than happy and recommend it to all. And we use our pj as a TV the whole time.
    Now just need the Lektropacks 'Magic Wand' to somehow lower the image on screen with no effort.:D
  12. MrCoopz
    MrCoopz
    Jun 28, 2002
    1,107
    63
    +115
    where do u get the AVIA and Platinum discs from??
  13. General Skanky
    General Skanky
    Jul 28, 2000
    4,251
    71
    Colchester
    +44
    Searched with www.dvdpricecheck.co.uk for the best prices. But don't get too hung up on having to have them. Very useful tools but your own judgement will be good enough as you perceive it. Just set up as you like to see it.
    Avia is very good indeed, don't really bother with the Ultimate Platinum disc, it's not as good. And before anyone says you must use AVIA, remember it's about £35 or so. It will give the ultimate set up, but if like me, the rules are there to be bent and I tweaked it more to how I like it.:rolleyes:
  14. Walter mitty
    Walter mitty
    Aug 1, 2001
    232
    19
    Shropshire
    Mr Coopz..... I thought you had the Pro v like me? It`s very good for Sky, at leaste I think it is brilliant I get all channels off Sky.
  15. MrCoopz
    MrCoopz
    Jun 28, 2002
    1,107
    63
    +115
    I do have ProV but my picture looks kinda grainy, do u use the same settings for ur PC as u do Sky?
  16. Walter mitty
    Walter mitty
    Aug 1, 2001
    232
    19
    Shropshire
    Mr Coopz,
    I set up pro v by splitting the video out to tv and Pro v from my video recorder, I have tried all the settings on the Pro v ie/ the resolutions, not a massive differenc ,It`s a really really good picture.
    I was tired last night but tonight am going to experiment with the projector settings a little but doubt I can better this pic it`s better than I ever imagined very clear smooth
    Since I havent yet played with the projector settings I`m not sure what they are at ....I`ll let you know later tonight if I get a chance,
    By the way my mate has a Barco and he`s well impressed I reckon he`s gonna sell his and get one of these as my picture is far superior
